Home › Forums › Products › Rackmount › Can you connect to the H9000 with emote and Vsig with wifi? › Reply To: Can you connect to the H9000 with emote and Vsig with wifi?
#152937
jfirlik
    Yes, this is possible.  With the included wi-fi dongle plugged into a port on the H9000, navigate to SETUP > NETWORK and find your wi-fi network.  Enter the password if necessary, and wait until the connection succeeds.  If you're on the same wi-fi network on your macbook, the H9000 should show up in Emote, and you can use the displayed IP address to connect in Vsig as well.
