Home Forums Products Rackmount Can you connect to the H9000 with emote and Vsig with wifi? Reply To: Can you connect to the H9000 with emote and Vsig with wifi?
#152956
bsfreq
    I kept loosing connection between emote and the H9000 when using the included wi-fi dongle. Even when having my Macbook Pro only half a meter away. After connecting the H9000 to my wi-fi router via ethernet cable and having my Macbook connected to router via wi-fi, the connection seems solid. (I’m using the Apple Airport Express 2, but I bet any proper wifi router will work just fine) I’m able to use emote on two Macbooks simultaneously, and all the settings are mirrored without delay. Not sure how many emotes we can have connected at the same time, but two is enough for me.
