Home › Forums › Products › Rackmount › H9000 1.2 and VSig 3.0 Public Betas › Reply To: H9000 1.2 and VSig 3.0 Public Betas
Thanks Joe, great info! Great news about the tempo preference in presets.
I decided to do the update last night – I noticed a change regarding SKNOB, i use this extensively and see that when the algo loads, it’s not using the value obtained from the merge like it was before the update – is that a known change, Vsig to H9K
Now merge doesn’t work but “default” now does. However when using an alternate source to determine what the MAX should be for this knob, I can’t set default higher than minimum. Does that sound expected? maybe a question for dbaylies
Re Emote 1.2.1[9], where can I download that? I’m still on version from this thread, 1.2.1[3]
Thanks for your help
