Home › Forums › Products › Rackmount › H9000 1.2 and VSig 3.0 Public Betas › Reply To: H9000 1.2 and VSig 3.0 Public Betas
Thanks Joe, got that now, awesome!! Didn’t realise it was that easy to change the values in the DB file!! I can now change REVDLY max delay from 250ms to 32500 and that should just work?
BTW, the module: dtonicii appears to support user defined scales; so we actually have the ability to do custom scales on H9000 if I build the algo?
That makes sense regarding SKNOB with Multiband compressor – so basically you’re thinking an Interface module similar to MKNOB but with more flexibility, enabling each contained knob to have it’s own min max but they work together?
Thanks
Yes, thanks. We’ll keep thinking about it. One common use case in the H8000 algorithms is to ensure that a group of knobs have values that are in order. For example, frequencies of a multiband compressor. I think that pattern could be captured more usefully in a single user object that has multiple values that are constrained to be in order by the module itself.
Show More...For the issue of “default” in sknob3, I think it should be possible to fix this just by updating the vsig database (sigdb) file. I’ve attached a new file for you to try. You can specify the sigdb file in the vsig settings but I found I had to restart the app for it to read the new file.
