Home Forums Products Rackmount Eclipse not Properly Bypassing with Digital Connection Reply To: Eclipse not Properly Bypassing with Digital Connection
#153088
    It would appear that the Eclipse does not mute on bypass with a digital output. There is presumably a reason for this, but it is not obvious.
    But, good news ! There is an alternative.
    The {MSTR OUT} gain control will mute all digital outputs and can be MIDI controlled, so if you use this instead of BYPASS it should meet your needs.
