Reply To: Eclipse not Properly Bypassing with Digital Connection
Home Forums Products Rackmount Eclipse not Properly Bypassing with Digital Connection Reply To: Eclipse not Properly Bypassing with Digital Connection
#153089
JordanBerliant
nickrose wrote:
It would appear that the Eclipse does not mute on bypass with a digital output. There is presumably a reason for this, but it is not obvious.
But, good news ! There is an alternative.
The {MSTR OUT} gain control will mute all digital outputs and can be MIDI controlled, so if you use this instead of BYPASS it should meet your needs.
FYI—there is nothing in the documentation about the Eclipse not being able to mute on Bypass with a digital out.    In fact, the manual suggests just the opposite.   I hope you guys will flag this for a fix in your next software update.   If there’s a reason it will not mute on bypass with a digital out, I’d be curious to know what it is.
Thanks for the tip on the MSTR OUT.   I’ll have to try that.   Can you assign an ext. setting to control the mute on the MSTR OUT?    I’d really prefer to be able to achieve the mute with the Bypass so that there’s visual reference on the unit itself.    I hope you guys will fix this.
