Reply To: Can you connect to the H9000 with emote and Vsig with wifi?By J20056 / Home › Forums › Products › Rackmount › Can you connect to the H9000 with emote and Vsig with wifi? › Reply To: Can you connect to the H9000 with emote and Vsig with wifi? November 9, 2019 at 8:36 pm #153159 J20056Participant I do, problem is fixed, but only using the IP address worked, not by name
