Home Forums Products Rackmount H9000 Emote issues (VST) Reply To: H9000 Emote issues (VST)
#153173
KYXTA
    Many thanks for the speedy reply.
    Yes, sorry, that is what I meant by Effect Parameter.. Yes, I am assigning FX asignments, and when I assign those to a parameter, they show up above the dial on both the Emote and the H9000 screen. They FX 1-1 etc parameters also come up in Ableton, and also on the PUSH 2 controller. It’s just changing them in the DAW or on PUSH does nothing to EMOTE.
    I am presuming that I control the FX parameter in the DAW, which control EMOTE as a plug-in, which in turn communicates with the H9000 via ethernet (As it does when I use EMOTE)… No MIDI connections are required here as it’s not using the MIDI CC protocol – correct?
