Home Forums Products Rackmount Expression pedals in H9000R problem Reply To: Expression pedals in H9000R problem
#153207
floresp640
    J20056 wrote:
    This is my last residual problem since getting the H9000R about a week ago.
    I hope someone can help?
    I was able to reproduce this issue. It looks like it is calibrating but the calibration screen isnt following. If you right click any algorithm parameter, it should open up the 'mapping' window. From there, press 'Learn'. You should see that the expression pedal is now mapped to the parameter. You can stil calibrate it using the 'pedals' tab in the session page but it wont be represented.
    Please let me know if this works.
