Home › Forums › Products › Rackmount › LogicX Channel EQ Algo? (H9000) › Reply To: LogicX Channel EQ Algo? (H9000)
November 17, 2019 at 5:10 pm
#153231
Closing this thread as little traction. Here is my workaround:
1. Setup an FX Chain with the White Noise algo followed by EQ Compressor (9503). The latter has a built-in EQ with two shelf and two peak EQ filters, whihc is plenty.
2. Send the output to DAW, I use Logic. Insert Logic EQ Channel, and at the lower left, select “Analyzer”.
Voila! You can see graphically the impact of the H9000 on the entire audio spectrum.
Hopefully useful for others. What would be awesome is an Emote window like the Meters window that does this to avoid the external DAW step, but I’m fine for now.
