Home Forums Products Rackmount Need a resistor value for Eclipse Reply To: Need a resistor value for Eclipse
#153435
    R1416 is a 10 ohm resistor.
    Worryingly, it is connected between the chassis and signal grounds – this suggests that you have had a major grounding issue or lightning strike, which has probably caused further damage. Just changing the resistor is unlikely to fix the unit – you may need to send it in.
