Home Forums Products Rackmount Strymon pedal after eventide eclipse in series Reply To: Strymon pedal after eventide eclipse in series
#153436
    I think you'll have to try it and see. Use the 1/4" jack outputs from the Eclipse to avoid balancing issues.
    Full level on the Eclipse will be more than the Strymon can handle, so you'll need to play with levels.
