Home › Forums › Products › Rackmount › H9000: -24dB maximum gain reduction in expression pedal mapping? › Reply To: H9000: -24dB maximum gain reduction in expression pedal mapping?
#153654
rvickers
    J20056 wrote:
    Why is there a -24dB lower limit on the gain reduction that can be applied to the output of a module? I want to use one expression pedal as a volume master pedal, but with a high headroom guitar amp, -24dB is still very audible, so essentially, I cannot lower the volume to zero. I don’t know if I am doing somehting wrong or else, but this is a problem.
    Please let me know.
    PH
    well, now you can use your SBGL.  I do.  :-). Cool that they would add to the H9K though.
