Home Forums Products Rackmount H9000: -24dB maximum gain reduction in expression pedal mapping? Reply To: H9000: -24dB maximum gain reduction in expression pedal mapping?
#153655
J20056
Indeed.
@eventide: The gain control to -Inf instead of -24dB is no longer a priority for me as I went back to using my SwitchBlade GL which gives me full volume control of each virtual cable. if you have no other need for it, then do not worry about it on my behalf. What I care about the most now is the ability to use Scenes via MIDI PC changes. I’m good on everything else as I am going to loop ADAT to connect FX Chains. Another pet peeve of mine is the inabilty to do direct connections in FX Chains (not in the Direct Connection area). Seems that the only way is to insert a Thru module that consumes 1 out of 4 modules.
