Home › Forums › Products › Rackmount › H9000 Data Wheel fine control mode “stuck” › Reply To: H9000 Data Wheel fine control mode “stuck”
Hello All,
I've come across a way to get fine control from the Data wheel, (which is sorely needed on some controls like reverb time where the values can go from zero to like a million!)
Pressing the Enter key on the number pad without entering any data first puts the data wheel in this fine control mode, however there seems to be no way that I can find to EXIT this mode
Anybody have any clue how to do this?
cheers,
Patchen
Apologies for not replying sooner. We didn't see your post originally because of a bug in our forum software.
The way the fine control is intended to function is that it will do fine adjust while the enter key is held, and revert to normal operation when the key is released. It sounds like you've found a bug where it's getting stuck in the fine mode. We'll investigate.
