Home › Forums › Products › Rackmount › H9000 96k issue with 5743 GloriousAngelics › Reply To: H9000 96k issue with 5743 GloriousAngelics
February 23, 2020 at 4:13 pm
#154143
senordelaflor wrote:
When I set the clock to 96k and add the algorithm 5743 GloriousAngelics to any of the slots in my FX Chains, all the audio gets distorted and it sounds broken. If I replace the algorithm with something else, it works fine. This algorithm should be supported for 96k, since it's not in the list of algorithms not supported in 96k and also the H9000 does not throw an error like some of the other algorithms that truly cannot be run at 96k. Can you please push a fix?
Thanks for the report. We'll look into it.
