Home Forums Products Rackmount H9k Reverb times go to 100 and are very difficult to control Reply To: H9k Reverb times go to 100 and are very difficult to control
#154236
joeydego
    patchen wrote:
    Greetings all, Whenever I try to adjust the reverb time on a preset I find it almost imposible to adjust the value as most of the reverb times go to 100 seconds.
    If you want to play with values betwwen .5 and 3 secconds for a ‘normal’ room you are basically out of luck as that is basically all within the first couple pixels of the knob’s throw. The knobs used have no taper and neither the hardware or the Emote app utilize any kind of knob acceleration which might help.  You can shift+drag but it is still just so fiddly.  It doesn’t seem reasonable that you have to use modifier keys just to set a reverb time to a normal value. I love the sound of this box but this aspect of the user interface is really killing it for me.
    Is this something we should expect a fix for or is this the way it is always going to be on this box?
    Do the earler boxes, Orville/H8000 suffer from the same problems?
    Can you click or double click on a value and type it in?
