Home › Forums › Products › Rackmount › Need to connect Eclipse and UAD Apollo via Digital in/out › Reply To: Need to connect Eclipse and UAD Apollo via Digital in/out
March 10, 2020 at 8:43 am
#154280
General tip – if you only see a single ADAT optical connector for In or Out, the max you’ll get is 48k. The ADAT spec/design only supported 96k using the SMUX/dual connector approach.
