Home Forums Products Rackmount “Kamikaze Drops” on the H9000? Reply To: “Kamikaze Drops” on the H9000?
#154460
floresp640
    Ed Driscoll wrote:
    Hi Guys,
    Glad to see that everyone at Eventide is staying safe and doing OK working remotely at the moment. I was using my H9000 earlier tonight to try to recreate the pitch drop echo effect that's called "Son of Kamikaze" on the H3000 Factory plugin version, and a similar effect that I believe is called "Kamikaze Delays" on the hardware H3000. The closest I could get was by fine-tuning the #7614 Magic Echo algorithm. Are there any other algorithms I'm overlooking that can best dial in that sort of effect?
    Thanks,
    Ed
    Hi Ed!
    I was able to get pretty close to this preset using a combination of a few algorithms! I used 3 algorithms in series, Harmodulator, H910/949 and H3000 Micropitch.
    I'll email you the preset and also take screenshots of my FXChain and algorithm parameters and email it to you.
    It's not exatcly like Kamikaze delays, I still have to work on the envelope follower but I think its pretty close. I hope this helps!
