Home Forums Products Rackmount H9000 users: what is your use/workflow????? Reply To: H9000 users: what is your use/workflow?????
#154492
rskaudio
    I mostly am using it for music mixing and hopefully will get it integrated for production as well but am only a couple months in.
    So far, I’m running 8 i/o Analog and 8 i/o of AES fed from a Digi 192 (while anxiously awaiting the HDx card…)
    My template has the first two engines with a stereo pair in each, the 3 third with two stereo pairs and the 4th running 4 stereo pairs. This leaves some room to add in additional processing on sources if needed and I’ve even run the first two as two FX fed from mono inputs summing to a stereo output when needed.
    Curious to hear more of other peoples setups, have been overall really happy with the box.
