Home › Forums › Products › Rackmount › Does H9000 run hot? Can it be sandwiched between other gear in a rack? › Reply To: Does H9000 run hot? Can it be sandwiched between other gear in a rack?
April 4, 2020 at 8:52 pm
#154506
brysava wrote:
I’ve found my H9000 to run relatively cool (lots cooler than the H8000’s, as it has a fan), and the unit’s heat vents are on the side, anyway, so it seems to me it would be fine to have stuff on top or on the bottom.
That’s correct – the vents are on the sides so it’s a good idea to have some space on the sides of the unit, but having a piece of gear on top should be no problem.
