Reply To: Does H9000 run hot? Can it be sandwiched between other gear in a rack?
Home Forums Products Rackmount Does H9000 run hot? Can it be sandwiched between other gear in a rack? Reply To: Does H9000 run hot? Can it be sandwiched between other gear in a rack?
#154547
macgee
tmoravan wrote:
I know it’s probably not an authorized mod and will void your warranty, etc, etc, but was it a software controlled command to adjust the speed or was it hardware/resistor type of modifications?
good point, i got it done by a company that is authorised in London based on feedback by Eventide – arranged through my dealer
but also, this might not be necessary as mine was an earlier unit and also the fan might not bother you – it’s just good to know if it does bother you you have options
