Home Forums Products Rackmount H9000 Feature Request: Stereo drag and drop Reply To: H9000 Feature Request: Stereo drag and drop
#154626
cyborgssc
    tmoravan wrote:
    Drag and drop is very intuitive and can be great for lots of things.
    However, something like setting up large routing configurations may be faster using an old-fashioned matrix with inputs across the top and outpts down the side or something.  Then you’d just click the boxes where the I and O intersected.  You could add intelligence to prevent illegal routings and such, but an approach like that might make setting up the initial config faster.  Then you could use the graphical drag approach for the special cases or to tweak it.once the base configuration is set.
    This is what I meant by referencing Dante Controller above. The main route creation is exactly the matrix you describe. However, this gets tedious for cases where you just need MADI outputs 1-24 routed to DANTE inputs 1-24. For that, Dante Controller has a drag/drop interface in its Device view – you just multi-select the desired outputs and drag them onto a device’s inputs. They also have a full save/load preset system for routing that uses XML files.
