Home Forums Products Rackmount H9000 Setup Questions Reply To: H9000 Setup Questions
#154642
joeydego
    iVardensphere wrote:
    Thanks for the reply. You guys rock. The H9000 does connect to the internet and I have updated it directly from the menu on the front panel. It is operating in version 1.2.2 (3)
    I reinstalled Emote (again. latest available revison) which still does not see any sort of H9000 connected. Just a blank, black screen with the option to manually enter an IP. I’m not familiar with juggling IPs so I’ve shy’d away from doing that thus far. Both the H9000 and the computer are on the same network which, according to the manual should work.
    Are you trying to connect wirelessly? just run an Ethernet cable. They’re dirt cheap and it’ll give you rock solid performance. I had hit and miss results wirelessly.
