Home › Forums › Products › Rackmount › H9000 burn in? › Reply To: H9000 burn in?
May 1, 2020 at 8:45 am
#154781
jbamberg wrote:
The backlight might also have a limited lifespan, but using the screen dim feature (which can be enabled in the Preferences page in SETUP mode) should extend it.
Yes, the range is from 0 to 10. However, the difference between 0 (off) and 1 (on) is faaar too great for fine adjustments. 1 should be much darker.
