Home › Forums › Products › Rackmount › H9000 burn in? › Reply To: H9000 burn in?
May 1, 2020 at 2:06 pm
#154783
Are you using the screen in H9k constantly?
I use mine occasionally but mainly using emote now.
So have mine setup to reasonable brightness and then it dims to zero after a couple minutes or so.
I had the same concern as you so asked your same question and now use as above to make the screen last longer
