Home Forums Products Rackmount H9000 burn in? Reply To: H9000 burn in?
#154784
joeydego
    macgee wrote:
    Are you using the screen in H9k constantly?
    I use mine occasionally but mainly using emote now.
    So have mine setup to reasonable brightness and then it dims to zero after a couple minutes or so.
    I had the same concern as you so asked your same question and now use as above to make the screen last longer
    The screen can be set to turn off?
