Home › Forums › Products › Rackmount › Momentary bypass on Eclipse possible? › Reply To: Momentary bypass on Eclipse possible?
May 27, 2020 at 4:46 pm
#154968
OK – finally got to an Eclipse. You can remote the global wet/dry mix (see UM for info).
If you set it to (say) EXT1, you can plug a footswitch into PEDAL1 and it will do what you want. You may have to fiddle with the switch wiring to get it right.
