Home Forums Products Rackmount H8000A (led) meter issue Reply To: H8000A (led) meter issue
#154981
    Just to confirm:
    You say the Eve/Net level meters work fine, but the H8000 front panel meters only show overload ?
    If this is the case, it suggests a problem with the H8000 front panel electronics. Most likely, it is the ribbon connector going to the front panel. If you are handy, you could check this. Otherwise it needs a service visit.
