Home Forums Products Rackmount H8000A (led) meter issue Reply To: H8000A (led) meter issue
#154983
    The 20 pin single row connector drives the display only, so is not the issue. The one you should be looking at is a flexible plastic ribbon connector.
    The led meter itself is made of an array of single leds. The problem is more likely to be the led drivers or a connector rather than the leds themselves.
