Home Forums Products Rackmount H9000R Emote 1.1.5[2] on Catalina Reply To: H9000R Emote 1.1.5[2] on Catalina
#155021
jfirlik
    wurst wrote:
    Thanks for the quick reply. I’ll try that out in a bit.
    I wonder though: wouldn’t it be easy to do a 64-bit build of 1.1? I’ve never built releases for OS X, so I might be missing something, but I’d assume you still have the source code for 1.1 somewhere and if the only difference is 32- versus 64-bit a compiler flag flip might be all it takes.
    Yes indeed, it’s a little bit of work but we will likely do this as a more permanent solution now that we realize its an issue.
