Home › Forums › Products › Rackmount › Momentary bypass on Eclipse possible? › Reply To: Momentary bypass on Eclipse possible?
June 25, 2020 at 1:24 pm
#155216
hangnef wrote:
I'm very curious as to why assigning say, external controller 1 which is my momentary footswitch, behaves as a latching switch when applied to FXA bypass, global bypass (bypass actually seemed like a tri state, wet, bypass, and no audio at all), etc. Is that due to those being an on/off type of thing, and global wet/dry is 2 different values?
This is because the controller drives the bypass switch, which is a press for on, press for off control. Whereas, as you say, wet/dry is a value, so the switch drives it directly.
