Home Forums Products Rackmount Eclipse 4.01 – 296 Micropitchshift + 182 Tapdly+Diffchorus = Freeze Reply To: Eclipse 4.01 – 296 Micropitchshift + 182 Tapdly+Diffchorus = Freeze
#155250
    Sorry you are still having trouble, but as you will understand, it is difficult to diagnose difficult problems remote ly.
    Can you confirm the following:
    1) You have done the full reset (SETUP held down at powerup, and you get an "are you sure" type message.
    2) That the problem still occurs if the unit is kept powered up after reset ?
    3) That the problem still occurs if you don't tweak the presets ?
