Home Forums Products Rackmount Eclipse 4.01 – 296 Micropitchshift + 182 Tapdly+Diffchorus = Freeze Reply To: Eclipse 4.01 – 296 Micropitchshift + 182 Tapdly+Diffchorus = Freeze
#155261
    If I understand you, the problem only occurs after you change something – if you just run a factory program things are fine.
    This would point to a fault in the data save system, although this would usually give an error message.
    So, it has to go for service – nothing we can do from here.
