Home Forums Products Rackmount Internal checksum error V4 eclipse Reply To: Internal checksum error V4 eclipse
#155262
    Look at "Fixing and Initializing Internal Memory" on UM p.53 to clear the bad checksum message.
    If it comes back later, change the battery again. If this does not fix it, or it comes back immediately, you have a hardware fault.
    If you actually do have a hardware fault, it has to go for service – there is no magic fix. It can be a bad memory chip, or faulty parts in the shutdown circuitry.
    Our UK distributor should be able to fix it – it should not have to go back to the US.
    London
    44 020 8962 5080
