Home › Forums › Products › Rackmount › Low signal from AES output of H9000R and no ADAT › Reply To: Low signal from AES output of H9000R and no ADAT
June 30, 2020 at 7:43 pm
#155272
J20056 wrote:
I made some progress by changing the input sensitivity of the DAC and ADC but it’s weird that I have to do that because when using the digital inputs, there shouldn’t even be any DA or AD conversions. Anyways, it worked and I picked up a lot of db’s so I’m good. I also found how to select ADAT for the digital input/output but it appears that one has to decide whether you want to use ADAT, AES or SPDIF but apparently only, one can be used at a time. I’m ok with that as I work in 48k, so 8 digital I/O is plenty.
Hi im having trouble locating the ADAT inputs within Emote. Can you Share with me how you were able to chose ADAT from input list? I see that i have to choose Adat over AES or SPDIF from your comment
