Home › Forums › Products › Rackmount › Eclipse into X32 Mixer › Reply To: Eclipse into X32 Mixer
July 16, 2020 at 6:48 pm
#155363
Attaching external devices, for the X32 rack, consisted of going to routing and assigning Aux Out 1/2 to Mix Bus 1/2 then linking Mix bus 1/2 and setting level to 0 (infinity). Then going to Aux FX and linking 1/2 and setting to 0 (infinity). Then going to vocal channel and raising send to desired level to blend wet/dry. Doing this I notice the signal barely registers yet I hear some reverb and FX.
I am thinking, after reading your response, that my concept of how this works is not correct. Are you suggesting I raise the send to 0 and perhaps use the mix control in the Eclipse to achieve desired level of wet/dry mix effect?
