Home › Forums › Products › Rackmount › ADAT Sample Rate H9000 issue with Apollo x8p › Reply To: ADAT Sample Rate H9000 issue with Apollo x8p
August 25, 2020 at 10:22 pm
#155621
Are you using the USB audio from the H9000? If not, there is no benefit to having the USB cable connected. I took mine out. I’m on PC, so perhaps you have it set up as an aggregate device in OSX. For only ADAT and audio use, you dont need it for anything.
