Home Forums Products Rackmount Does H9000 run hot? Can it be sandwiched between other gear in a rack? Reply To: Does H9000 run hot? Can it be sandwiched between other gear in a rack?
#155697
ThreeFingersOfLove
    jbamberg wrote:
    drxcm wrote:
    Would prefer a fan control in firmware, but if I were to for example modify my unit, what would I need to do?
    Is the Noctua a plug and play kinda connection to the motherboard?
    We chose the H9000’s fan mainly for its quietness.  I wish my home office were quiet enough to hear it!
    Adding fan speed control to the firmware is something we’ve been meaning to do for ages, but it kept getting pushed down the priority list.  However, since you and others have brought it up, I’ll see if I can get this done in the coming weeks, after the current beta is out.
    I don’t know the specific fan you are talking about, and I’d hesitate to recommend modifying the H9000 yourself.
    Can you modify the H9000 with a Noctua fan prior to the H9000 leaving your factory?
