Home › Forums › Products › Rackmount › Does H9000 run hot? Can it be sandwiched between other gear in a rack? › Reply To: Does H9000 run hot? Can it be sandwiched between other gear in a rack?
#155703
tmoravan
    Thanks.  That’s kind of what I have found out when doing work on old effects units.  The specifications of the fan are only part of the story.  How it’s mounted, the layout of cards and components inside the unit, the overall airflow through the unit, they all contribute to the perceived noise.
    I appreciate the spec sheet and I will keep the screwdriver away from my H9000 and wait for the OS update.  🙂
