Home › Forums › Products › Rackmount › Clock Source in an Mac aggregate device, Who is the master? › Reply To: Clock Source in an Mac aggregate device, Who is the master?
September 6, 2020 at 3:26 pm
#155722
maxenbit wrote:
– Any other recommendation for better performance using the H9000 in this DAWs as an external FX Device using USB?
If you want to use Ableton's MIDI to control the H9K there's a slight workaround you may need to use to avoid overloading the H9K's MIDI buffer if you're sending a lot of MIDI messages at once.
Instead of sending MIDI messages directly, you can use Max for Live to control the speed of MIDI messages by making a patch like this, and then controlling the [live.dial]
