Home Forums Products Rackmount H9000R w/Dante card not found in Dante Controller Reply To: H9000R w/Dante card not found in Dante Controller
#155785
monads
    I’m going to chime-in because I’m a little confused by this setup.  And there’s always different setups/scenarios/challenges.
    I’m on the same:
    OS- Mojave 10.4.6
    Dante Controller 4.2.5
    I’m not sure what audio interface you’re using and/or with Dante installed?  I do not have the H9000 w/Dante connected directly to my MacPro.  Instead I have a PCIe Dante card installed.  This is then connected to a network switch.  My MacPro is also connected via/Ethernet port to this network switch.   The H9000 w/Dante is also connected to the network switch.  I don’t have ANY issues when I launch Dante Controller recognizing equip.  Although sometimes Dante Controller forgets ‘saved’ settings.  I saved a default studio setup and it’s as easy as pie reloading Dante with the equipment ON prior to executing.  For me works flawless.    I LOVE Dante but there’s additional expenses to setup properly.
    Are you using the Dante Virtual Soundcard??  Do you have a dedicated Dante audio interface and/or network switch???  Just curious and to help others looking to setup Dante properly in a network studio.  For me it was a bunch of literature reading and trial but I’m happy to share knowledge.
