Reply To: H9000 session reset – FX chain reset
Home Forums Products Rackmount H9000 session reset – FX chain reset Reply To: H9000 session reset – FX chain reset
#156031
Pombero
This is great information, thank you. It have been checking the I/O levels and none of that that has moved. It seems like sending a stereo signal into some of the algorithms is killing the levels. But it is hit or miss and doesn’t affect all algorithms. For example if I feed stereo audio into Ultratap the levels drop significantly, but if I switch it to mono then it works fine and the I/O is balanced. I don’t remember this ever happening before, so it also could be something on the DAW side, or maybe with my Apollo interface.
