Reply To: Controllers for H9000
Home Forums Products Rackmount Controllers for H9000 Reply To: Controllers for H9000
#156040
jbamberg
joeydego wrote:
Can I use my pre existing Akai MPD226? It’s currently usb into the computer. I never use the 4 knobs or 4 faders on it for anything. Can it serve double duty somehow??
You can plug the controller directly into the H9000 of course (via any of the USB A ports on the front or rear), but assuming you want to keep it connected to the computer, you would need a way to route the incoming MIDI from the controller to go out through the H9000 USB connection (the rear panel USB B connector that also carries USB audio).  We can certainly look into it.
