Home Forums Products Rackmount H9000R MIDI CC Capability? Use with MIDI Virtual Racks Reply To: H9000R MIDI CC Capability? Use with MIDI Virtual Racks
#156072
John Baylies
    Yes, you can use MIDI CC to select different presets from the MIDI VirtRacks.
    Right-click the <<<<TWEAK #1>>>> dial and click MAPPING. The mapping window will open on the right.
    Set the Source to 'MIDI CC Single', set the MIDI CC and channel to the CC you want to use, and set the Action Type to Momentary. Then click Apply.
    All of the <<<<TWEAK #1>>>> dials will now display a green line around the dial to indicate it is mapped.
    Unfortunately you can't save presets within the algorithm itself in Emote, and the Vsigfile can't be downloaded into Vsig3 due to a Device Download Error that we're aware of.
    The CC values are not 1-10 either. They are as follows:
    tweak # – MIDI CC value
    1 – 1
    2 – 15
    3 – 30
    4 – 43
    5 – 57
    6 – 71
    7 – 85
    8 – 99
    9 – 113
    10 – 127
