Home Forums Products Rackmount H9000 full reset overnight – all personal data gone Reply To: H9000 full reset overnight – all personal data gone
#156140
jbamberg
    Edgar9001 wrote:
    Good morning …..again all data lost after switching on my device…this time a backed up all data on the USB drive.
    Well, must be a battery issue maybe within the H9000? Any help please gladly appreciated…
    Sorry you have had this problem.  This is most likely not an issue with the battery.  It is probably that the persistent filesystem got corrupted somehow.  Please could you try a full factory reset – power on the H9000 while holding the SESSIONS, FXCHAINS and ALGORITHMS keys.  You can release the keys after the Eventide logo appears on the screen (a few seconds).
    If this turns out to fix the issue, I think we will need to consider adding a "Shutdown" command in the H9000 system.
