Home › Forums › Products › Rackmount › Booting H9000R in recovery mode with PC › Reply To: Booting H9000R in recovery mode with PC
#156257
qepic7
    jfirlik wrote:
    Hi there, Sorry to hear you’re experiencing issues. Has the H9000R ever appeared in Emote? (in other words, is this an intermittent issue or a more prolonged one?) It would be helpful to know more details about your network setup, as the issue may be in the configuration. In addition to the network connection between your H9000 and your computer, the Recovery mode also requires an internet connection to your H9000 (unless you are using a USB Recovery installer).
    Thanks for your reply.  The H9000R is connected to my PC with a wifi internet connection via ethernet.  I was able to use it when I first set it up at the end of September, but I started running into spotty connection issues in the past 3 weeks with Emote.  But after using a wifi adapter to perform the latest update-which was so frustrating I don’t know how I actually successfully updated the H9000R or Emote- nothing works.  I was literally a couple of failed attempts away from getting rid of my unit, before updating.  But now the situation is worse.  I have flushed the DNS, refreshed the ip addy, restarted the 9000R and my PC, tried to start recovery mode via the pin hole next to the network button, but no response except for the occasional connection error message that instructs me to manually create a new H9000R profile.
