Reply To: H9000R stereo autopanner
Home Forums Products Rackmount H9000R stereo autopanner Reply To: H9000R stereo autopanner
#156535
joecozzi
A few more questions:
sdd17 wrote:
I am running the unit fully analog and returning on a console! So 4 mono sends multed to the analog stereo inputs on the h9000r and 4 separate stereo outs returning to my console!
Have you checked that audio is going into the H9000R using the metering? Have you checked if audio is coming out of the H9000R in the same way? if the algorithm is working properly, you should see the meters rise and fall as it auto-pans.
Are you sure all four channels on your console are active?
Quote:
By the way I pulled up some other stereo effects like a ping pong delay and the stereo movement was working!
Are you recalling these algorithms within the same FX Chain? Are you sure the FX Chain inputs and outputs are routed to the Analog 1-2?
