Home › Forums › Products › Rackmount › Eclipse SPDIF Usage › Reply To: Eclipse SPDIF Usage
December 28, 2020 at 4:42 am
#156694
Thanks NickRose.
I noticed that too on p. 23 and am not sure whats wrong with the digital input signal. I’ll see what the Focusrite folks have to say.
I can confirm that Clock is set to DigIn and DigIn is set to RCA. I do note that the Clock is says “DigIn…….. kHz”. I’m assuming that the Eclipse is expecting a particular sample rate? Is that what the periods mean?
Yes thats correct I set everything to 48kHz, only because I thought that was best for SPDIF. But I can try it at 44.1. Do I have the concept correct? I can use SPDIF to send audio out form the DAW and back?
Thanks again for the help!
