Home › Forums › Products › Rackmount › H8000 Routing and SP/DIF › Reply To: H8000 Routing and SP/DIF
#156728
    I'm afraid that this is probably one of those problems that cannot be fixed without being there. Sorry.
    I would suggest that you try and find a local technician to look at your system.
    If you think the unit is faulty, you should send it in (again) with a very clear description of the simplest possible setup to illustrate the problem.
